Tach not working!
Old Aug 25, 2011 | 09:28 AM
dphc18's Avatar
Default Tach not working!
I did a LS1 swap into an LT1 car and change the entire harness and gauge cluster to LS my volt & temp gauge are working but the Tach is not any ideas or can someone tell me where the tach gets its signal so I can check that wiring.
Old Aug 25, 2011 | 11:26 AM
psiconversion's Avatar
LS1Tech Sponsor
Are you getting the TACH signal from the Class 2 Serial Data?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Aug 25, 2011 | 09:52 PM
itsslow98's Avatar
Yea me and Jon^^^ worked on this for my swap. Just splice the Class 2 serial data line into the grey wire on the cluster I believe its like pin B9.
Here is a small write up I did on the cluster swap.
https://ls1tech.com/forums/conversio...ow-inside.html
Old Aug 25, 2011 | 10:29 PM
dphc18's Avatar
PSIconversion: I show RPM's on a scanner just not on the gauge,
itsslow98: I change the complete harness from a crashed 99 into a 95 so I don't see why I would need to do what your saying even the cluster belongs to the harness its just not working
Old Aug 25, 2011 | 11:42 PM
itsslow98's Avatar
If thats the case then maybe the cluster is damaged internally. The cluster recieves a signal from the PCM and interprets that data inside the cluster, it then displays the info on the gauges. Sounds like you may need a new cluster.
Old Aug 26, 2011 | 12:57 AM
Dillon93dillon's Avatar
http://lt1swap.com/lsx_tach.htm
this link here might possibly help solve this problem
