LS1 stumbles and tach flutters (video)
Just as the tiltle says... Its in a 70 camaro with a t56. 99 and up wiring harness. I was wondering what sensor controls the tach? Is it the reluctor wheel? Thanks guys
![](https://www.youtube.com/watch?v=ZNOdfp-Xbx8)
or
http://www.youtube.com/watch?v=ZNOdfp-Xbx8
or
Where are you picking up the tach signal? I had to use a pull up resistor with my Autometer tach for it to even work. You may need one to stabilize the tach needle.
Andrew
Andrew
If it's only the tach that's misbehaving, here is the tach ckt remedy, courtesy of FastKat-after you redirect to this thread, scroll down about 75% http://www.buyrcars.com/jag.htm
