Pros VS cons mechanic gauges or electric
Can anyone think of any pros or cons of using mechanical vs. electric (engine Oil pressure/ water temp and maybe trans temp)gauges? I am looking to go Autometer C2. I've always used mechanical in all my builds growing up but am I missing a added bonus running electric gauges?
thanks,
Jim
thanks,
Jim
Electric gauges all the way. Simple to hook up, clean installation and no oil lines running inside the car too.
What if you want to change up your gauge panel once you've been driving the car because you don't like where a certain gauge is? Then all you have to do is extend/shorten the wires for the gauge.
I've had weirdness with electric oil pressure senders before, so I always use mechanical for that (mine is all braided lines/AN fittings, no cheesy plastic/brass lines), but I run electronic for everything else.
Honestly, at this point, I'd probably have gone electric for oil pressure too, if I was doing it over. The last time I had issues was probably almost 10 years ago, I'm sure things have improved since then.
240z, cons, electric, electrical, electronic, gauges, lq4, ls1tech, ls3, machanical, mechanic, mechanical, mechincal, oil, pressure, pros, reading
