Carbed LS1 in a 3rd gen
If that doesn't work try starting it with the lap top connected. the MSD software will tell you if you are getting a crank signal or not.
How old is your ignition box? Some of the early ones needed software updates to help with the low RPM crank signal.
That should be installed straight up for most builds, dot to dot with no advance or retard on the timing chain. THEN you use the MSD software to dial in your timing curve or use those plastic pills in the side of the box. You need to open the software on your laptop while hooked to the msd box and the ignition on to see cranking rpm on the tach on the screen of the laptop.
