need help mating richmond 5 speed to 4.8
Project is 63 corvette. Already have iron block 4.8l LS1 and a Richmond 5 speed tramsmission. I know I need to use 621 bellhousing. Want to use stock 06 GTO clutch and flywheel and also do hydraulic clutch conversion. Research says clutch master cylinder from 85 1 ton truck will bolt ritght up. But what to use for throw-out bearing, and is the GTO clutch assembley ok...Thanks
https://ls1tech.com/forums/conversio...ion-2-0-a.html
Andrew
