F-body accessories on LQ9
I have searched but maybe I overlooked this information. Anyways, I am wanting to use f-body accessories on an LQ9. My question is what is the best way to to this without a ps pump? Can I use stock parts to make this work? Not using AC either, but I think that is a different belt.
Also do I need the balancer and the crankshaft pulley from an f-body or just the crankshaft pulley?
Appreciate the help.
FYI, The Balancer and Pully are one unit.. but is two peices. there is about .75" different in off set between the Truck and F-Body ones.
Yes the AC is on the inner pulley of the Balancer. No AC.. no issue then.
Would just suggest using everything from the F-Body if that is what your going too.. you can either try and re-rooute the belt without the PS, there has been some threads on doing that. or you would need an aftermarket Alt bracket setup (idler pulley also ?). Kwik are a common vendor to use.
Agreed with bczee. Don't waste your time looking an F-body bracket when there are plenty of other places that have alternator only brackets. Kwikperf.com comes to mind first but I think there are a few others. Kwik is nice because all their stuff comes 3 different ways to match the truck, F-body and Corvette crank pulleys.
Thanks for the information guys. So pretty much my best option is to use a aftermarket setup? From what I have seen, I am not sure if I can use the fbody Accessories without the ps pump.
