Ls1 / 700r4 questions
Old Dec 24, 2016 | 08:45 PM
sowbelle's Avatar
I mated a 2002 5.3 to a 700r4. I just used the stock flexplate, the Hughes spacer, elongated the flexplate to converter bolt holes. I also used a Bowtie Overdrive TV conversion cable. Follow the directions in the kit. No problems whatsoever.
Old Dec 28, 2016 | 02:44 PM
Ozz1967's Avatar
Originally Posted by JoeNova
If your trans has lockup, its easiest to use a toggle switch. The stock ECU won't control it. There are other methods, but they can get fairly complicated.
My 700R4 has been built with an internal lockup kit. Fairly rare these days. No need for an external lockup kit.
