LS T56 Bracket
Old Oct 4, 2011 | 07:35 PM
dropped72ss's Avatar
Default LS T56 Bracket
I need the hydraulic clutch bracket that bolts behind the brake booster. My car has power front discs. Do i need to go manual to make this work? I don't see how the clutch master would fit behind the power brake booster? Anyone with a 70-72 chevelle w power brakes done this? Any help would be much appreciated.
Old Oct 5, 2011 | 12:31 AM
bczee's Avatar
Yes. you can find the template in the FAQ.. it does work well.. S&P markets one.. you might find other on the internet. it is not hard to make from 1/8" or 3/16" metal.
I bolts behind the booster and against the firewall. the Master will then be below the booster and angling away from it. If you look at a 4th gen master. the firewall mounting surface is at a angle. Which is why you need the bracket.
1st page of this thread show the template.
https://ls1tech.com/forums/conversio...ro-basics.html
Also if you research on some of the there swap threads you will find info..
You can see what I did on my swap by using the link in my sig..
Old Oct 5, 2011 | 08:26 AM
Thanks, I found one on eBay looks to be of quality for 30 bucks.
Old Oct 5, 2011 | 08:42 AM
chuckd71's Avatar
I bought (but have not used) this - http://www.ebay.com/itm/ws/eBayISAPI...X%3AIT&vxp=mtr
Can't speak for the fit but the quality of the piece and it's finish is very high. Of course we are talking about $30 for a bent piece of metal, but nevertheless it is higher quality than I expected. I think 71fakes bought one as well.
Old Oct 5, 2011 | 12:09 PM
71Fakes's Avatar
Yep, bought the same one. Good quality. Sadly, I am in the same situation as chuckd71...it is sitting on the workbench...
Old Oct 5, 2011 | 01:09 PM
Ok Thanks guys. So the 4th Gen master cylinder is What everyone uses? I've bought the original GM 4 speed pedal kit so There's not much more I need to get the trans into My chevelle.
