New Product for In-Tank Fuel Pump Conversions
I use Walpro 255gph GSS340 pumps. I love tinkering with my car and making things in my spare time, even if it appears to be a waste of time to you. I wish I had all the money I spent on things that didn't work out.
Can you upload other pictures of your setup? I saw pictures before the link was removed and it looked to me like the return line doubled as secondary mounting support for the pump(s) through zip ties (assumably fuel rated?). The primary support for the pump was its own fuel line. Is that correct?
I''m having trouble uploading the pictures, but you're correct about the return line. I looked up every material that I used and all of it has righ ratings for gasoline. Retrofit-in-tank-fuel-pump-assemblies. See, that's not a link. Or there's in-tank-fuel-pump-conversions. Thanks for the idea of the top photo.
50, aeroquip, assembly, conversion, conversions, efi, fuel, intank, ls1, modification, psi, pump, retrofit, retrofitting, tank, tray
