64 chevelle wagon swap
Thanks,
Mack
There are not a lot of CHEAP solutions when it comes to getting all the "little" things integrated like the guage cluster, wiring, computer programming etc. But, my recommendation is to do a search through the forums here. Most of the questions you are asking have been answered... many of them with nice diagrams and pictures of how people have done it.
http://www.geocities.com/hrayhouston/antisurgetank.html
It is a buttload of work and it will not be cheap, but the end result will bring a smile to your face!
Regards, John McGraw
1. You can make your own plates that look like S&Ps out of 1/4" steel for about $10.
2. Walbro 255lph in-line fuel pump ($130) and '99+ Corvette fuel filter/regulator (~$40)
3. The "Parts For Sale" and "Parts Wanted" areas on this forum are good places to find things sometimes. You can put a post that says something like: "Waterpump wanted, will pay $50."
Can't help you on exhaust, but there's lots of stuff out there. Like grooves12 said, so some searching and you'll find that most problems have been addressed and are explained in good detail. Also, take whatever budget you have and add another 50 to 100% to it. That's what you're going to end up spending. I know I'm already there and I'm a couple of months from starting it up.
Good luck,
Matt
Thanks,
Mack
Thanks,
Mack
the oil pan will not clear the crossmember. I opted to have S&P modify mine and polish it. I am using the F-body pan.
I moved the braces on the frame for the trans xmember back about 6 inches and rewelded them and that seems to work just right to mount the trans.
I am running the vette brackets because the f-body alternator will not clear the steering box.
the F-body and Y-body a/c compressor will not clear the motor mounts in the back. The fitting on the compressor sticks out too far. I plan on using a vintage air unit. It is a little bit smaller and you can get the fittings on side instead of straight out the back.
As far as exhaust is concerned, I live near Stainless Works and they told me, when I was ready, I could try their headers for an LS-1 in a '67 camaro. They look like they might work. Not cheap though. I cant try it till I get the body back on the frame though.
My only concern with wiring is where to put the CPU. I was thinking about having it so the CPU is on one side of the firewall and the plug is on the other. I would like to try just under the driver side fender. You can order a wiring harness from painless with 4 extra ft. for about $649.00.
I also had Be-Cool build a radiator that will bolt to the chevelle core support and has the in/out the same size/location as an F-body radiator, that way I can use factory hoses.
I have a tank from Rock Valley that is set up for return line so I had to have the fuel rail converted to the return type.
I have pictures of a few things if you are interested.
