gen 4 g body wagon swap dbw question
I have a new style 07 silverado 4.8 in my malibu wagon and the dbw pedal is not going to work.In the right position,it hits the framing around the column..but the pedal has a huge curve in it.Will camaro pedals interchange?
I have also yet to find anyone to tell me if i can use cruise since this is electronic throttle..and my car has factory cruise.
As far as dbw pedal..im way over budget and the only other option was a Lokar pedal or customizing the one i had.Me and my bro in law came up with an idea.I made a steel bracket that mounts to the brake booster then the master cylinder holds it on and i mounted the pedal sideways,cut some length off of it and ran my factory cable end through the plastic pedel with no slack.Works like a charm.
LS1Tech Sponsor
Vette pedal wouldnt have worked?
Jon
PSI
Jon
PSI
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic84531_2.gif)
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
