Fuel pump relay control - C101 Pin D voltage?
Hi,
I am having a few problems, 1 is no spark which I have read up on what to check but the other which I can't find the answer to is about the fuel pump.
I have an LS1 from a 2000 Camaro.
What voltage reading should I get at C101 pin D (fuel pump relay control)?
I know I am feeding to the correct wire on the car because when I put it to 12V the fuel pump works.
Thanks
Thanks
