No power steering below 1k rpm
put it up on a jack today, lock to lock probably twenty times, checkd the level and topped it off.
dropped it to the ground, and with the engine a 600 rpm, i could turn the big 38.5/14.50 swampers on my truck.
Happy that this fixed it.
thanks guys
thanks guys
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Come to think of it, I noticed what could have been aeration, as I noticed bubbles in the oil when I checked the level. The longer I drove, the noisier the pump became....
With my luck, I had a good pump, but had plumbed it WRONG!!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
[$165.00 later]
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
THANKS!
I had the return on the upper port. I will swap it to the lower port on the new pump.
With my luck, I had a good pump, but had plumbed it WRONG!!![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
[$165.00 later]![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
THANKS!
[$165.00 later]
THANKS!
I actually did it with a walbro 255 fuel pump. replaced it thinking it was my fuel pressure issue. ended up being return line issues.
so NOW I GOT FOR SALE A WALBRO 255 only ran for a week
so i have the exact same problem, no steering at low rpms, and i know exactly how i broke whatever it is i broke. I was doing donuts in the snow and right after that it happened. maybe that will be able to help you car people figure it out.
