Team Z/LSx swap Kmember
No way would I run a stock pan on any thing planning to be raced.
The oil control and pick up location of the stock pans is not suficcent. By the time you buy the things to try and make a f body pan work you are at the price of a moroso.
Every part on my car has required some kind of mod to make it work better on the car.
Tim
Tim
my only reason for using the stock pan currently, is for budget...
right now, the car is no where near close to race... though, I have raced with this pan and did not have any major issues...
and I honestly dont need to buy the moroso pan to do the rest of the work on the car to get it driveable...
I plan on buying a moroso pan before I go down the track in the mustang as it should be considerably faster than what I was running last year in the camaro
I had a 10.97 in a 3800lb car on motor, and I had several aborted passes due to some electrical issues, and some lack of traction when I tried to spray...
never had a good clean pass on the giggle gas due to multiple problems.....
then I decided to go foxbody...so none of that mattered any more.
