LSx with t56 into foxbody questions.
I have a foxbody with a cable clutch t56 setup out of a cobra and a UPR k-member. Im going to fab up some custom mounts to work with the UPR k-member but other than that what would be needed to make the t56 work with the LS1? Also anything else id have to do to get the LS1 to work in there? Some insight on the wiring and fuel system? Thanks in advance!
LS1Tech Sponsor
This is a very straight forward swap and you should be able to find a lot of information on this board. Wiring is straight forward, we have a standalone harness for your application.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
