DBW in my boat?!?
Ok - going to switch from carb to EFI in my boat this winter. I will be using a Fast 102 LSXRT intake, but I haven't figured out how to get the throttle cable mounted.
So - here's a question. I need a floor mounted pedal - is there any floor mount pedal that will work with DBW?
OR... Does someone make a flexible extension that will snap onto the end of the boat's Morse cable to operate the throttle body. The boat's stock throttle cable is a 14 foot long Morse cable and not nearly flexible enough to make that wrap on the throttle body, but 6" extension would work if it exists.
Otherwise.. ?????
http://www.ebay.com/itm/05-12-CORVET...item27c001ed94
Otherwise.. ?????
I've been reading these boards forever. Since I'm fixing to drop an LS1 in my jet boat I thought it might be time to finally join. Once the Glastron is done, the 79 GMC short wide will be next. Then probably my other jet boat if the Glastron works out as well as yours did.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
x2. You could probably make it work with any boat throttle since the sensor is only held on by 2 screws I think and there is a flat head screw driver tip (basically) the goes into a slot in the pedal to rotate it. Should be pretty easy unless the throttle needs the cable tension to stay in place.
