Diesel Trans Am?
Old Nov 17, 2011 | 02:47 PM
Firebird Phoenix's Avatar
Default Diesel Trans Am?
I know with "enough money" anything can be done...but is it possible to to bolt up say... the 6.6L Duramax diesel engine to a T-56 and into a T/A? Discuss..
Old Nov 17, 2011 | 02:55 PM
Ellsworth's Avatar
Bolt up? probably not..
Old Nov 17, 2011 | 08:20 PM
Saturn5's Avatar
You probably can, but I would think the T-56 would be shredded by the torque without some serious beefing up. Then you'll also need a clutch to hold it. Lots of people have swapped Duramax engines into cars, but I think they usually use the transmission that comes with it. Do a search on YouTube for Duramax Chevelle.
FYI, the engine is HUGE. Bolting it up is one thing. Physically getting it in the car is another.
Old Nov 17, 2011 | 08:33 PM
Zmg00camaross's Avatar
Dont know if you can beef up the front end enough to hold the weight.
Old Nov 18, 2011 | 02:17 AM
EODguyJake's Avatar
I would agree with all of this. I can't see a T-56 liking the torque, if it could keep it in the power band. Also, I don't think you could physically stuff one in a late model car. I much more educated and informed on the diesel scene than I am with my T/A (but that will change soon) and I haven't seen one stuffed in a late model sports car of any kind (I have seen 1 or 2 4BT Cummins floating around in smaller cars). They have started to stick them in the old muscle cars. One in say, a 79 T/A would be badass.
On another subject, anyone wanna buy a rust-free 79 in project condition?
Old Nov 18, 2011 | 07:21 AM
ramairetransam's Avatar
stay with the allison trans .
Old Nov 18, 2011 | 08:04 AM
BOBS99SS's Avatar
Captain Double Post
i have seen it done in older camaros, honest buddy you said it, if you have the money anything can be done, your going to need a pretty large amount of cash for sure
Old Nov 18, 2011 | 08:03 PM
skypilot_1's Avatar
Throw enough $$ @ Gale Banks and he'll bolt a diesel to a Saturn IV!
Old Nov 19, 2011 | 09:00 PM
Saturn5's Avatar
Cool
How about a Saturn V? They already are diesels.
(The F1 engines run on Kerosene, not Hydrogen. It's called RP-1. It's similar to jet fuel)
Old Nov 19, 2011 | 09:07 PM
blackls1ta00's Avatar
are you serious?thats stupid,go put it in something thats worthless then
Old Nov 19, 2011 | 09:10 PM
metalmilitia606's Avatar
There is a duramax camaro project floating around on here. Last I saw it he was shooting for 800 horse and 1200 lb/ft torque in a fourth gen. This was at least 2 years ago so I don't know if he is still going with it.
Old Nov 19, 2011 | 10:56 PM
raven_450's Avatar
http://realperformancemustangs.com/s...iesel-mustang/
Old Nov 20, 2011 | 12:13 AM
matt01ws6's Avatar
i just rode in a 800 whp duramax tonight acually. and in one of these cars holy **** is all i can say
Old Nov 20, 2011 | 12:12 PM
96Formula6spd's Avatar
One guy put a GM 6.5 in a camaro. Here is the video.
http://www.youtube.com/watch?v=FHfx-..._order&list=UL
Old Nov 20, 2011 | 01:18 PM
6.0Nova?'s Avatar
The ignorance of diesel is strong in this thread, luke skywalker.
The Duramax weighs about 840lbs. An 8.1L big block weighs 865lbs. Iron LT1 weighs about 500lbs....a Duramax isn't *that* heavy.
Duramax uses a standard V8 Chevy bolt pattern, so a T56 will bolt up. It should do a decent job of handling the power, with the right clutch. Most Duramax stick shift trucks came with a shitty dual-mass flywheel from the factory, so that is something to watch out for. The real trans. killer with diesels is low-RPM impulse torque.
The allison is huuge, it won't fit in most car/Dmax swaps, and takes a 2" body lift to fit it in a stock Silverado, so a TH400, built 'glide, or maybe a built 4L80E would be better, depending on what you want to do with the car.
The engine is wide as *** too, it has 4 valves per cylinder. Everything else might not be an issue if you can't squeeze the engine in the car.
Old Nov 20, 2011 | 01:39 PM
the_merv's Avatar
Veteran: Air Force
The Duramax Block is pretty similar to the 6.0l Ironblock..I saw one the other day at the machine shop. The Heads are massive..like mentioned.
Old Nov 20, 2011 | 04:51 PM
violent_celerity's Avatar
You could track down the truck 6 speed if you've got really deep pockets.. I can't remember the model designation but it's a ZF something or other. They were behind duramaxes for a few years and the 8.1 liters. But from what I hear, that transmission is huge so I doubt you could fit it into an Fbody.
Old Nov 20, 2011 | 05:14 PM
the_merv's Avatar
Veteran: Air Force
It's similar to a NVG4500..and that thing is a beast.
Old Nov 20, 2011 | 05:58 PM
Thanks for the informative post. I'm just slightly interested in the thought of a diesel in my Trans Am maybe one day. What other V8 diesel options are there that could fit (or what is the measurements on the Duramax?)?
Old Nov 20, 2011 | 07:21 PM
NemeSS's Avatar
Is there a reason u want a diesel? I work on diesel vehicles and equipment for a living.but I would not bother retrofitting a large diesel in a car. If tq is wut u seek, a big block will pretty much drop in ur ta, bolt up to a LT1 type t56.
I'm sure that big block motor will be more than adequate. And lower priced than a diesel
