Time for another build...2001 Miata L33 w/t56 conversion
#61
#62
Thanks guys.
Here's an updated/obligatory pic of the engine bay with 'Vette engine covers. A BUNCH of time and effort was spent here to make it look this simple and un-cluttered. All engine wiring is done, and I'm really happy with how it turned out. We still have to fab the air intake, and finish a bunch of other stuff...but it's coming along nicely now. I'm hoping for completion late next week.![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
[IMG]
[/IMG]
[IMG]
![](https://www.fquick.com/images/vehicles/full/39980359156.jpg)
#63
What wiring harness/PCM did you use? I've got an 01 miata that I'm fixing to put under the knife and the 5.3's are looking more and more affordable. I want to use a cable throttle body and was wondering how you did this?
Thanks!
Thanks!
#65
As far as videos go, sorry for the delay. I'm driving the car daily (already logged 3500 miles), but am also still working out some bugs in the car. I've got to do a lifter swap in the next month, then off to the dyno to finish the tuning....videos will follow of the car on the dyno, and then on the road hopefully
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#67
Right now, the car is out of commission. What started as a quest to just replace the LS7 lifters with "high dollar" pieces, turned in to an excuse for more upgrades. Currently the car is getting the following;
EPS Cam .598 .595 113+3
New lifters....again...only this time a good set
New double springs, retainers, keepers
C5R Timing chain and Hex-a-just gears
ATI 10% underdrive ballancer
Fast 102 Intake
Fast 36 lb/hr injectors
Custom pushrods from Smith Bros.
90mm Throttle body
LS6 PCV system
I FINALLY got the ballancer in today's mail, so most of the reassembly should be completed tomorrow or Friday. I still have some wiring to change a bit, as well as fab a new throttle bracket for the intake. It looks like the Vette engine covers are going away, so I'm looking at billet or fabricated valve covers along with coil relocation brackets in an attempt to keep it as clean looking as possible. Time will tell how that goes.
Providing that startup goes well, the car should be headed to the dyno in the next week or so. I'll post back here with some more pics after that.
#68
LS1Tech Sponsor
Hi James, I just replied to your e-mail. Let me know if you have any questions.
Thanks! Bob
Thanks! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#70
What's the duration of that cam. PTV clearance may be an issue without a flycut depending on duration & head gasket. Bump the CR with a thinner gasket while you're in there. Increased CR is cheap HP for very little work.
#71
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#73
Thanks. Take a look around this site, and you'll see a few of them :-) Also, do a search for Mnivet...he did a mid-mount t76 that was 630rwhp. His is the inspiration for me to research (again) options for FI. If I can fit the Procharger, that's what will go into this car....if not, it'll be the same kind of setup as Mnivet. I'm just hoping to keep as much ground clearance as possible, which is why I've not yet jumped on the turbo install.
#76
It's been a while since I've updated anything here...and some plans have changed.....
I got an absolute steal on a killer Callies/Diamond 383 LS1 rotating assembly, so I've decided that a forced-induction 5.3 is no longer in this car's future. For now, it's an 11.5:1 383....so we started in again on the mods...
I never did like the IAT's that seem to come with the mediocre-designed "cold air" intake setups that are so common, so I started looking around for other options. The LS7 "snorkel" style airbox seems to solve the problem...so, more cutting/modding has been under way....
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
After all of this, I decided to have the front of the car re-painted...which turned into a complete re-paint. I just got the car back a few days ago, and will start reassembly as soon as the new radiator gets here. The 383 will be a couple of months away from completion, as I'm also in the middle of a twin-turbo swap on my formerly single-turbo'd fbody.
Too many projects going on right now for myself and customers, but hope to have this car completed (if that's really ever possible) in the next 2 months at most....just in time for the new dyno to get here and start tuning these things!
More updates to come....
[IMG]
![](https://www.fquick.com/images/vehicles/full/39980371076.jpg)
[IMG]
![](https://www.fquick.com/images/vehicles/full/39980371075.jpg)
[IMG]
![](https://www.fquick.com/images/vehicles/full/39980371077.jpg)
#77
Nice. I saw that on flying miata's site under the v8 conversions. Looks like a great idea. I'm seriously considering getting a honda s2000 and swapping a LS3 in. import muscle has kits. S2000 look better I think, and weigh in a few hundred pounds over the miata and still have 50/50. Also, can fit a larger tire.
#78
That car is an absolute monster!! I helped with the fab work on the turbo kit along with many other changes to the car. Its a blast to be in to say the least!
#79
I still want to throw some boost at mine eventually. I'm still assembling the 383, so I have time to make some head chamber size decisions....plus I just pulled a single t76 off of my fbody....so who knows how long it'll actually sit around
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
I also gapped the rings on the new engine for boost, so I guess that's a sign of things to come. lol I just get so damned indecisive on these things sometimes. Worst case scenario, I'll throw a boost-friendly cam and heads at it and just drive it like that until other projects are finished...then get back to it with a lot less work to do, and just run the plumbing and fuel upgrades....
