Project Ugly Betty LQ4 with a 4L60E into a 1966 Mustang
![](http://i1227.photobucket.com/albums/ee429/mmag0428/Ugly%20Betty/DSC02343.jpg)
If anyone has any questions or comments about this front end setup I would be happy to answer. IMHO this kit was well built. once you get past cutting up your factory suspension it went together real smoothe and the directions were clear.
Been making some headway over the last couple of weeks. Swapped a car intake and Kwick brackets are in and they clear the stock hood. Disassembled front end, painted reinstalled. Headers are cut modified and wrapped, Sub frame connectors are in, putting together fuel system now getting ready to put valve springs and oil pump, chain, seals in motor then reinstall. Next major purchase is a Harness and computer flash. Have to call PSI! Lots of photos.
hey how did the 4l60 trans fit,, u have to cut floorpan any? hey russ what kit did u use? thanks guys,, wife has a 66 we putting a 5.3 all aluminum motor in... thanks monk
Wind Mill: The 4L60 needs some tunnel cutting and massaging. I cut the factory cross member brace out and then used a rose bud tip to heat the tunnel where it meets the firewall back about 8 inches then slowly worked the metal. We then reinforced the floor with 1/8 flat stock. Not as bad as you would think but I'm glad that this part is done
#32
Windmill; I used tci kit for the suspension and mustang steves power brake booster conversion.
S10xgn I know that you used a detroit speed power steering pump flow reducer but what fitting did you use to adapt it to an line? Part number? Any help? Thanks mike
#33
#35
Baggings I will get the number tonight. It was the one where you make your own bracket and he sends a list of Boosters and mastercylinders and a new pin for the brake pedal. Even with my modest welding skills i was able to make the mods in 2 hours.
#37
Baggins: the kit i got was the basic kit where you have to fab your own brace. wasnt hard I know that you can send your brace to him annd he will modify it for a price. Hope this helps. Mags
