Project Ugly Betty LQ4 with a 4L60E into a 1966 Mustang
#47
Russ, I know there are hydrboost kits but they were outside my budget. I also found some info on swaps but I thought it looked complicated, lol after what we have accomplished I should have tried it. I will look and see if I saved any of that info.
#49
Im doing the same build on my camaro, I ran into one of many issues. The latest issue is the torque converter wont bolt to the LQ4s flexplate. Any ideas? Money is tight to say the least!!!
#52
She lives. Betty stared right up last night and ran smooth. 1 trans line and 1 power steering hose had small leak otherwise perfect. Now I have to assemble the rest of the car. About 40 days to ls fest. I will post the video when I get back in town. Thanks again to all the people on this site. Couldn't have done it wthout your help and good friends!
#53
Start up video more picts to come Link to video
http://s1227.photobucket.com/albums/...t=betty175.mp4
#54
Fenders, hood bumperrs are on and lined up nice for a mustang
Coolant fan won't turn on. Scanner says temp at 230 no ground signal. When I manualy ground relay fan torns right on. Any ideas before I am forced to go with an aftermarket fan controoler.
Thanks mike
Thanks mike
#56
she is back up running!!! oil pressure is a steady 45 psi at 190 degrees. Thanks Sal, Dale and Josh. it took all of eight hours to get her running. My Lesson learned is dont assume that the O ring that came with the new oil pump is correct! I used the red one this time.
#59
Beertestr. The members name who I copied is firstgenguy. I found it under the spectre tanks yea or nay string. His write up was easy to follow. I had to modify hisplans slightly but it wa easy enough. I have more picts of it if needed.
#60
Sixt5 any thing I can do. Sa_swaps did his with the towers. Josh is a great guy helped me all the time. He has great picts on his build string. Le me know what you need.
