MAF Harness Extension (how to?)
Old Nov 26, 2011 | 05:35 PM
Blue67LS2's Avatar
Question MAF Harness Extension (how to?)
I just discovered the harness for my LS2 5 pin MAF needs to be longer. I can't find anyone that offers an extension harness, so it looks like I will need to splice and add some additional wire to increase the length.
I'm very relunctant to cut into my new harness without knowing the potential negative consequences (if any) of doing so? Obviously, I know I will need to make sure the splice is done properly and be sealed to protect against the elements, but are there any other issues or precautions I need to be aware of? Any suggestions other than cutting the existing harness?
Much thanks...
Old Nov 26, 2011 | 06:02 PM
i r teh noobz's Avatar
Nothing to be afraid of. Just cut and solder.
Old Nov 26, 2011 | 06:46 PM
FatfreeGTO's Avatar
I have to do the same thing with mine. While mine reaches the MAF I don't like its routing because its too short. When I go to do the extension I plan on depining the MAF connector, adding my extension, and then crimping on new ends to repin the connector. I am going to do it this way so that there is only 1 splice in each wire and not 2 like there would be if you left the MAF plug connected and simply added wire in the middle.
Old Nov 26, 2011 | 07:20 PM
rotor vs. piston's Avatar
If the cables for the MAF aren't shielded you should be fine, I just don't know if they are myself as I used the stock routing for my swap. If they are shielded, just get another shielded wire and make an extension.
Old Nov 27, 2011 | 10:12 PM
JMitch19's Avatar
Much thanks...
I believe that the MAF you have uses a flat 5 pin GT150 connector.(might be a metri pack depending on year) If you can find a source what will sell the connector in low quantity cheap enough you could build your own adapter harness.
I have the parts at work to build you one if you can't find one for a reasonable price or don't want to make it yourself.
Old Nov 28, 2011 | 07:42 PM
S10xGN's Avatar
Stagger your cuts so the splices aren't all in the same place, so the harness doesn't look like a snake that swallowed a small child...
Old Nov 28, 2011 | 09:19 PM
Rikoshay's Avatar
Or use a truck harness, the MAF leg is like 15 feet long.
Old Nov 28, 2011 | 09:26 PM
I have never thought of this and have hated my solder joints being so bulky. Will be using this for now on, thank you.
Old Nov 30, 2011 | 06:57 PM
usc2001gc's Avatar
They do sale harness extensions, if you prefer not to cut and splice. I purchased one from a website where you could choose various lengths. Here's a link to one on ebay (I can't remember who I purchased mine through).http://www.ebay.com/itm/GM-5-Wire-MA...item43a3740a9f
Old Nov 14, 2016 | 06:37 AM
Brad Hartpence's Avatar
Default Maf extension
How much longer do these wires have to be?
Old Nov 14, 2016 | 06:59 AM
1964SS's Avatar
Long enough to reach your MAF sensor.
Old Nov 14, 2016 | 07:24 AM
JoeNova's Avatar
Restricted User
I take it this is a custom harness and not a stock one?
The wires for the Truck MAF are long enough to mount the MAF sensor in the trunk.
Old Nov 14, 2016 | 10:02 AM
ls1nova71's Avatar
THis thread is just about two weeks shy of being 5 years old, I'm pretty sure the OP has finished it by now!
Old Nov 14, 2016 | 10:29 AM
JoeNova's Avatar
Restricted User
Yeah I usually pick up on that LOL.
Old Nov 14, 2016 | 11:53 AM
1964SS's Avatar
The thread is old. The person we responded to is from 5:37am this morning.
Old Nov 16, 2016 | 07:54 AM
Default Adding supercharger
I'm adding a 2010 ctsv supercharger to my 2007 ctsv ls2. Just poking around to see what all I have to do and came across this thread. I know it's old but it wasn't specific on the length anyone had to add for the swap...just wondering if anyone knew so I could get this harness off ebay before I start this project. Thanks
