Why does everybody recommend converting to drive by cable?
I searched and couldn't find a conclusive answer:
Is there a benefit to one over the other?
I see where drive by wire would be good since you just have to mount the accelerator. But drive by cable you'd have to mount the pedal, make sure the cable works, etc. etc.
Seems simpler to do drive by wire? Please advise, all opinions welcomed.
Regards, John McGraw
As was pointed out, later ECUs dont even have the capability for an IAC driver needed with cable TB.
http://www.youtube.com/watch?v=kzlg3...ature=youtu.be
Mind you, this isn't enough for me to jump over to DBC. It's just an irritation I've learned to live with. I understand some tuning adjustments may reduce occurrences. However, some people may be bugged enough by this slight disconnect between driver intent and computer delivery to make the conversion. It may be especially critical in racing scenarios.
If I'm going through the effort to complete a swap I'll go with what I like which is the cable.
If I have a 2004 silverado 5.3 engine and harness that came from the factory with DBW and I want to convert over to DBC using a PCM from a 2004 Express Van
Other than removing the tac wiring and adding the wiring for TPS and IAC and using a cable driven throttle body all of the other wiring is the same correct?
My big reason for swapping over is pedal options....I am limited to the bulky factory 2004 silverado pedal which have have already shortened.....but the switch housing takes up a lot of real estate in a 2nd gen camaro
Using the cable lets me keep the factory pedal so I know everything is in the right place and looks factory
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Or just do what i did and cut the pedal assy to a stump, bolt it to the firewall and cut and weld your factory pedal to the assy so it retains the factory pedal in the factory location. In my nova oddly enough there were two factory holes in my firewall that lined up..
