Fox body Mustang/4L60E Drive shaft Options
I can tell you for certain that those mounts will only work on a stock 4.6L K-member. The mount stands on the stock 5.0 K-member are positioned at least 2.5" further forward than the stands on the 4.6L K-member and sit at a different height and degree of included angle as well. If you are looking for mounts that allow you to bolt an LS directly onto the stock 5.0 K-member, Hooker Blackheart makes a set of engine mounting brackets that will allow you to do just that.
Thank you very much for your input!!!! I will check them out.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
