A-body swaps ... Are you happy?
Old Nov 29, 2011 | 03:32 AM
66-sd-BBB's Avatar
Default A-body swaps ... Are you happy?
Hind sight is usually 20/20 .lets hear it, now that you have completed your LS swap into the A-body , and ironed the bugs out, what would you have done differently - to save money , or buy brand X parts instead of brand Y because ...
Example , now that the long tubes , 4l80e , and autokraft pan are in , can you get at the starter motor ? Is the trans too tight in the tunnel to get at the bellhousing bolts and pull the trans later on etc. etc.?
Old Nov 29, 2011 | 07:02 AM
chuckd71's Avatar
Buy a good motor the first time. Be patient. Know what you want and just do that from the beginning. Don't worry about trivial nonsense that for all practical purposes will make zero difference in the final product.
Most of this stuff is detailed in build threads, and it's hard to say 'I should have bought X instead of Y' if you haven't used both.
Old Nov 29, 2011 | 07:32 AM
garys 68's Avatar
Other than the reliability, smooth idle, good gas milage, great torque, etc...I'm ok with mine
Old Nov 29, 2011 | 07:46 AM
oange ss's Avatar
Overall I am happy with mine, the only thing I would have changed is not buyin the worthless Hooker headers. I'm goin FI now so that problem is solved. I raised the transmission tunnel up about 2" so that I could remove the tranny when the need arises.
Old Nov 29, 2011 | 07:33 PM
66-sd-BBB's Avatar
Most of this stuff is detailed in build threads, and it's hard to say 'I should have X instead of Y' you haven't used both.
I am using this site a lot to help put together my plans, and have come up with many useful tips. Starting with a forged 24x ls3 385 long block from AES , topped with a front feed 2.9 whipple , and a good used 4l80e with the TCM and ECU ( reflashed) from the same donor truck. The original post was just part of my research , and apparently I should investigate Hooker headers to see how they compare to the other brands. Thanks for the replies
Old Nov 29, 2011 | 07:35 PM
speedtigger's Avatar
Old School Heavy
Mine exceeds all expectations. I just hate the valvetrain noise.
Old Nov 29, 2011 | 08:58 PM
66-sd-BBB's Avatar
How do you like the 2004r , and is it from extreme automatics?
Old Nov 29, 2011 | 10:05 PM
Project GatTagO's Avatar
Does your cam have a reduced base circle? You may just need longer pushrods.
Andrew
Old Nov 29, 2011 | 10:16 PM
flywheel's Avatar
I love my 6.0l/4l80e combo.... The first one is always the toughest. I wished I hadn't bought that POS spectre fuel tank. The LH8 pan wouldn't be my first choice now either.....I like my combo so well now, that i'm trying to sell my 454/5sp richmond set up out of my 66 to make room for an ly6/4l60e combo in it....
Rick
Old Nov 29, 2011 | 10:22 PM
jaydub's Avatar
Would past on the hooker headers, using a grand national gas tank wish spectre was out when I did my swap
Old Nov 29, 2011 | 10:38 PM
66-sd-BBB's Avatar
Rick
what did you use for engine and trans management ?
Old Nov 29, 2011 | 10:45 PM
Indecision's Avatar
Some good info, once I sell my LS1 RX7 I'm doing an LS2/3 swap on my 66 GTO. I don't know if JTR makes headers that will fit an LS* A-Body, but I have them in my car and they are really nice.
Old Nov 30, 2011 | 06:50 AM
Old School Heavy
The transmission is excellent. However, I probably would not choose Extreme Automatics again. I love Lonnie, but he is very slow and does not follow up or follow through. I would recommend checking out some of the other vendors on TurboBuick.com.
Old Nov 30, 2011 | 06:48 PM
FatfreeGTO's Avatar
I would set the engine as low and far back as possible even if it meant cutting out the trans tunnel. I actually would cut out the tunnel and fab a new one right off the bat. I currently have 2 3/4" between my passenger side head and the firewall moving the engine back would solve some other issues.
Old Nov 30, 2011 | 09:33 PM
hookemdevils22's Avatar
100% agree. and I have proper pushrod length (checked w/ the hi-tech pushrod length checker, and also tried .025" shorter to no avail). Ramp rates and increased lift from roller lifters certainly lead to some unique 'issues'!
One more thing... I kind of expected to be able to toss in a giant cam and 3600 stall and it still be completely easy and tame with roses and pixies dancing around. It still hates being cold (just like the old 350) and doesn't like lower rpm's (just like the old 350). And it doesn't get the gas mileage I was hoping for, but maybe that's because I get into it every-so-often... But dammit, you can't beat the easy start-up, general lack of ongoing tuning, 2,500 rpm's at highway speed, and ice-cold AC in a 515 hp car that's actually quite docile, despite 3" exhaust.
EDIT: I'd have sold the 4L80e and went with a T56 from the beginning! It's not going to be fun to swap it in now (though still totally worth it).
K, done with the X-body hijack
Old Nov 30, 2011 | 10:14 PM
66-sd-BBB's Avatar
A pre-fabbed tunnel kit would be nice- but the old 2004-r trans is small and can take 800 torque when built right. I would like to try a stock 4l80e to see what abuse it could take. here is a custom one http://www.popularhotrodding.com/tec...t/viewall.html
Old Nov 30, 2011 | 10:49 PM
flywheel's Avatar
66-sd-bbb, I used the BRP mount set up. TR cam, yank 3200 stall. in my 71.
Rick
Old Dec 4, 2011 | 12:01 AM
chuckd71's Avatar
The hooker headers are okay, or at least they do the job well enough. From time to time they pop up on ebay from a place in KY (near holley) and they go for $200-300ish which is hard to argue with.
Old Dec 4, 2011 | 10:36 AM
oange ss's Avatar
I wouldnt run those Hooker headers if they were free. If you do run them keep a supply of extra plug wires handy
Old Dec 4, 2011 | 12:31 PM
chuckd71's Avatar
Or just don't run wrap the wires around your headers. Either way works.
