LS1 to t5 questions...I searched
so it looks like i got my answer from another member, thesource, when i pm-ed him about my problem. looks like the parts list that will work for me reads as follows:
Quicktime bellhousing RM-6037
Ford throw out bearing
gm pilot bearing with ford inner diameter
ls1 flywheel
ls1 pressure plate
11" ford 10 spline clutch disk from 2000-up gt mustang
ls1 flywheel
ls1 pressure plate
Gregamuffin,
For LS1 Flywheel, I need something like from 1999 Camaro 5.7. Correct ?
Thanks
Waid
I have read there is a company that makes a .400" thicker flywheel for putting older gm manual transmissions behind LSX engines. This and pilot bushing is what should be needed.
