How to Mod Turck MAF, to get IAT???
Hoping some one could post a link, or tell me what wires I need to get out of the truck 2000 MAF to run IAT sensor. Im doing away with MAF, and need the IAT to do turbo swap, thanks? Like what sensor will work, what wires I need to keep? 2000 LQ4, came out of a Silverado.
LS1Tech Sponsor
You should be able to use a camaro IAT sensor.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Truck has the IAT built into the MAF. What year Camaro, do you know what wires? I have a turbo, and going with a Speed Density tune, so I can do away with the MAF, but I need the IAT.
LS1Tech Sponsor
Connector positions A and B, Black and Tan wires. IAT can come from any Camaro 98-02. LT1 would probably work as well.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
Just cut the IAT wires (Black and Tan sound correct) from the MAF connector and run them to any old GM IAT. I used one from a 96 Camaro, and it was the same IAT that goes on my friend's old Fiero.
Thanks alot! Went to pull a part got like three different kind to see if they work! I wanted one that had the pipe thread, so I could screw it in to the up pipe. 99Caddy/98 Grand Prix/96 Biuck Park Av. There were no 98 Camaros. The Aereo Force gauge I installed helped a lot! It shows that the 96 Buick works fine, all of them have the same plug!
LS1Tech Sponsor
MAF Scaling willl be different but as long as you want to play with it, I dont see why not.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
