LS1 Conversion motor mounts...
Old Mar 15, 2004 | 01:33 PM
grooves12's Avatar
Default LS1 Conversion motor mounts...
Does anyone besides S&P make motor mount adapters that allow the use of stock Small Block type motor mounts??
The look simple enough to make... I just can't see paying the mega-bucks S&P is asking, when the same thing can be made for probably $10 out of steel plate. Does anyone have any diagrams/measurements to use for making some plates?
Old Mar 15, 2004 | 03:04 PM
Mark IXZD 150's Avatar
I've seen some home-made versions but I have the S&P mounting plates and for the money they are sweet. There's more to it than just cutting the metal. They include the hardware, etc. The way I see it is if I have to spend more than an hour or two on something, $100 is a good price considering how valuable my time is.
Old Mar 15, 2004 | 03:42 PM
grooves12's Avatar
Thats understanable, but my uncle is a machinist and runs a shop with every fabrication tool imaginable. So, all I really have to do is show him a diagram and in a few days I have them for free.
Another question: for those of you that HAVE used the S&P mounts... is the motor placement EXACTLY right?? I mean is it truly in the exact same spot as a small block would be?? Do things like stock transmission mounts/driveline angles etc. all match up the way they did with a small block, or is there a lot more tweaking involved?
Old Mar 15, 2004 | 05:31 PM
MikeM79's Avatar
I used the S&P adapters for my swap into a '71 Z28.
Yes, they put the engine exactly where a small block would be along the "front to back" axis. If you are content with this location then the only clearance issue for that particular swap is the a/c compressor. The LS1 looks like it belongs there:
http://members.aol.com/MikeM79Z28/LS1TestFit.jpg
Given that the plates themselves have a certain thickness it could be that the LS1 would sit a tad higher than a small block, but this was not a concern of mine.
By Brett Foote | 2026-06-04 05:00:17
