Another 6.0 Fox Body
Old Feb 21, 2012 | 02:53 AM
6.0L mustang philly's Avatar
so i got a little fab work started on the hotside pipes. this is used diesel exhaust tubing. didnt cost a dime.
several 15* cuts were made to get a tight bend.
should flow good enough.
here is where the manifolds will merge.
smooth transfer
tac welded for mock up.
someone practiced welding on this tubing, nothing a grinder cant clean up.
the right side is the passanger side, basically mocked up. the old hanger will be cut off later.
feel free to comment my build, any ideas or questions
Old Feb 21, 2012 | 06:45 AM
Jameslt1TA's Avatar
Looking good. I see that your in Cheyenne. Is that your shop? I'm in Pine Bluffs.
Old Feb 21, 2012 | 09:24 PM
yep im in cheyenne. im using a friends shop to build my car. your not too far away.
Old Feb 24, 2012 | 11:24 PM
Talking wiring it up
finally ran "C1" and "C2" ecm connectors down through the factory harness hole down into the interior on the passanger side floor. took anbout 2 hours since i didnt remove the dash/ harness or any of the interior. also wired up the body electrical so everything works. tomorrow im going to start wiring up the engine, WISH ME LUCK!!!!
Old Feb 25, 2012 | 08:32 AM
toxic99's Avatar
Always nice to have a friend with a big shop for you to work in. Cool build so, far keep the updates coming.
Old Feb 25, 2012 | 09:00 PM
Wink
so today i mounted the battery in the trunk, ran 0 gauge welding cable from front to back, spliced in power constant and switched 12+ so now the ecu gets power with key on, starter works just like it should.
the wires will be cleaned up better once i know everything is working 100%
ignition working great!
Old Feb 25, 2012 | 11:41 PM
gregrob's Avatar
Whoever was driving the mustang in that video is a ma fackin BAWSE! lol....
(me)
Old Feb 25, 2012 | 11:42 PM
gregrob's Avatar
Holy ****, really?
You should come hang out / cruise / race with us sometime...
Were doing a few "bolt ons" for my 99 when I get home here in about 9 days
Old Feb 26, 2012 | 10:23 AM
Revoroller's Avatar
Looking good, what are you doing for gauges? wiring in factory, aftermarket or a camaro cluster?
Old Feb 27, 2012 | 12:59 AM
(me)
definate boss mode!
Old Feb 27, 2012 | 01:08 AM
going to try and get the factory speedo working, volt and fuel level will stay stock. everything else will be aftermarket, water temp, oil press, trans temp, wideband a/f, boost. going with prosport gauges. My origional plans were to wire in a cts-v cluster but the old ones are wayyy too pricy, the new ones are like twice as much.
Old Feb 27, 2012 | 01:09 AM
  #32
gregrob's Avatar
You need a dakota digital signal transformer to make the stock speedo work. Rip that junk ford **** out and dont waste time dicking with it.
Old Feb 27, 2012 | 01:21 AM
  #33
incorrect sir! the stock fox speedo is cable driven and so is the th400 i got..
Old Feb 27, 2012 | 01:36 AM
  #34
gregrob's Avatar
I forgot you working with an old enough pos to be cable driven lawl. Mikes is the mustang that needs the box. Carry on
Old Feb 27, 2012 | 01:47 AM
  #35
Talking epic fail like always!
listen closely youll hear the starter.
click the image
walk aroundish..
click the image
got some wiring done today, heres some harness uglyness!!! before
annnd after.
this was done a couple days ago.
covered up.
wire pinouts taped to the fender
got the nmu working.
ignore the ugly wire mess underneath. im just showing the stock truck oil pan clearance. its roughly 2" below the stock 4cyl x member.
just for laughs, cummins diesel turbo
it actually fits well.
external gate
someone said i couldnt do it, some said dont do it... i said
Old Feb 27, 2012 | 01:49 AM
  #36
thanks man! makes me feel great to own a ford!
Old Feb 27, 2012 | 07:55 AM
  #37
Revoroller's Avatar
I was going to use the stock cluster but I just couldn't justify only using two gauges on it and using after market for the rest, Im building a gauge plate similar to the mc machine but mine's steel and cut out with a plasma cnc and will retain the stock clear face on it. Let me know where ya get the speedo cable to run the stock cluster with a TH400, if its cheap enough I may run the stock cluster til next winter.
Old Feb 28, 2012 | 03:03 AM
  #38
yeah after looking at the cable i noticed its too short, it needs to reach the tailhousing on any 1st gen trannys on the other side. so it has to be changed, my phone has gps speedo. lmao thats all im going to use for a while.
Old Feb 28, 2012 | 06:01 AM
  #39
Jameslt1TA's Avatar
Holy ****, really?
Sounds good. I'm usually in Cheyenne every other weekend or so. I haven't drove the 11 Camaro in awhile, I'll have to come up and see your guys projects.
Old Feb 28, 2012 | 06:09 AM
  #40
Jameslt1TA's Avatar
The speedo in my camaro doesn't work either and I just use the gps speedo on my phone until I remember what rpm is what speed.
