abs delete????
Old Jan 2, 2012 | 10:48 AM
chevelleluvr's Avatar
Default abs delete????
Doing my lt to Ls swap and im trying to figure out how I do the abs delete. I seen in threads that they have done it but it doesn't say how and I would appreciate any help!!!
Old Jan 2, 2012 | 11:19 AM
turbinesurgeon's Avatar
All you really need to do is re-route your brake lines for a direct feed off the master cylinder, remove your abs module from under the hood, and remove your abs light from the dash.
Just out of curiousity, why do you want to delete your abs?
Old Jan 2, 2012 | 12:04 PM
Is there some other kinda module or block the lines are supposed to hook up to the that goes to to the master cylinder? Im removing cause the previous owner already removed all the the stuff for abs and just seems alot easier to keep going the same route..
Old Jan 2, 2012 | 10:02 PM
dutinsss's Avatar
all you need is to run a line from the MC to a proportioning valve, then T it into 2 lines that will run to the rear wheels. then for the front, just have your line run to a T that splits the line from the MC into 2 lines, one for each front wheel.
