Kwik accessory bracket issues
I can get all pulleys to line up pretty decently except the alternator, which seems like it's a rib or two too rearward. Before I put the underdrive on, the belt would walk off the crank pulley about a rib. Since the underdrive has taller walls that doesn't happen, it just takes maybe 4 hours of the engine running to make the belt squeal.
If there was a problem with the alternator alignment, I would think that the belt would be wanting to come off of the P/S pump though, right?
Anyone have an insight? I'm very close to just going with the F-body bracket and alternator..
My setup is all truck accessories, and now that I'm swapping in a 6.2 I'm going to have to mess with this stuff all over again and I don't even want to think about it.
Maybe you could put a couple washers between the alt mount and the block to move it forward some. Offhand I don't recall what the kwik p/s stuff looks like. Edit - are you using the combined kwik alt/ ps bracket? Maybe space the whole thing out with a couple washers then press the ps pulley on a little bit more to compensate for it.
I'm using the combined alt/ps bracket, with an 02' F-body ps pump and the plastic pump pulley from a GM 3.4L Kwik sent me to use. The kit does come with spacers I forgot all about that thank you for mentioning those.
The only thing that steers me away from using the GM setup is having to drill the block, which means I'll have to pull the front end off of the car to drill it and tap it perfectly.
Now, the truck alternator can be installed on an F-body with no alignment issues correct? I have an F-body alt without a stud for the batt cable which is why I got a truck one. Maybe I'll swap the alternator out and see if it lines up any better. I am using the Gates laser alignment tool to help out with this issue.
I am finding that the Camaro tensioner is a poorly built piece that deflects under load. Someone mentioned "camber". That's exactly what I found. I used a shim to "tilt" it back nearer "zero camber". I'm planning on a Katech tensioner. Looks like a much better piece.
The Sanden alignment is critical. FOLLOW the instructions exactly, when torquing the bolts!
I've added the tensioner pulley w/ the lips on the sides. Seems to do a better job.
All said and done: After 3 belts, many hours of work, I still have a small squeek...Probably get worse, too.
My next "test": I am going to install a dial indicator on the bracket face, and check to see how much the entire assy deflects when the belt goes under tension, and when the engine is revved.....
More later...
I haven't done the Katech tensioner yet.
I'm about at the end of the "phuk around" phase, and this mount is going on Ebag. The down side to that is, I have to notch the x member to put the stock location mount/compressor on. [Truck system].
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
I called Wayne @ Kwik this am... Waiting on him to call me back.
Jon
PSI
Ebay Store
You do have to ask for the right offset when ordering the brackets.
Jon
PSI
Maybe I wasnt clear on my question..... The kwik bracket requires you to use a remote reservoir power steering pump, which is typically NOT what comes with a truck pullout correct? Tiresmoker stated he is using the f-body pump.
Anyone else out there, would you have preferred to purchase a bracket that allowed you to use the pump that came with your engine (if you have a truck pullout) rather than purchase a new pump, reservoir and reservoir bracket?
Jon
PSI
Ebay Store
If that's the case w/ mine, I'd surely have preferred buying a kit that didn't require a pump change.
BTW, where do you see that pump info?
I'm using the Kwik AC bracket, very happy with it.
Btw, it says on their page:
What else is required to complete the installation:
Almost any Type 2 remote reservoir power steering pump
I never even knew I was required to use a remote reservoir since the pump on my truck pull out was broken and I was planning on a remote set up already. The main reason I wanted the remote set up was so I could make it a little larger to help with cooling the PS system since have hydraboost, do not currently have a cooler in the system though I can add one if needed down the road.
Jon
PSI
Ebay Store
