4L60E manuals?
I have a problem with trusting the tranny shops here in the area, and can't seem to find anyone who KNOWS someone who can do the work... wasn't really looking for a deal so much as someone I can trust. I want to change out the output shaft... but "supposedly" my tranny only has 17K miles on it, so I don't know that there is any reason to completely rebuild it... I don't want someone I don't know or trust to just pressure me into something I don't need... money is tight right now.
If I had a proper shop manual, I am confident that with my mechanical abilities and a decent array of tools as well as access to ALL possible tools if I need them, that I could open it up, replace the shaft and put it back together. Sooo... that brings me to my question...
Does anyone here know of a PDF'd manual for the 4L60E? If not, does anyone recommend a specific brand or issue of manual for doing such a job? If so, PLEASE help a brutha out! I should have my parts later this week and ULTIMATELY it would be great to work on it over the weekend.
Thanks in advance. BTW, I posted this same EXACT thread over in the automatic trasnsmission forum too... just want to cover bases here.
Coach... I mean Randy (I often forget who I really am)
Undergoing LS1 Coversion as we speak!
Click Image to Visit My Website!
TTYL!
Oh I forgot one step -- pull the extension housing off, but you probably already have that off anyway.
It will pretty much go like this:
1. Unbolt the transmission bellhousing (T47 torx if memory serves) Might not even be necessary, just look and see
Can't remember if the lip hangs over the pump face or not.2. Remove the transmission pan.
3. Remove the filter.
4. Remove the lockup solenoid -- its the one closest to the front of the transmission, going into the pump.
5. Remove the pump bolts.
6. Remove the pump. It'll be kinda snug, but you can lift 'em out by hand if you're strong enough
7. Lift the input shaft, drum and reverse input assemblies out all as one big chunk. Keep an eye on the 2/4 band, it might need a little coaxing to slip off the reverse drum.
8. Grab the 2/4 band that by now is either hanging in mid-air, or has fallen into the case.
9. Reach down and lift out the sun gear.
10. Grab your snap ring pliers (expanding type) and remove the snap ring from the top of the output shaft. This will be the most difficult portion of the swap
Assembly is the reverse of this process
The big things to be careful of are proper pump alignment, dirt and crap falling into the unit, forgetting the lockup solenoid or the filter in the pump, and tearing up the 4 teflon seals on the turbine shaft. When you put it back together, lube up the teflon seals with something -- believe it or not, the garage door lubricant "door ease" stick works great
Otherwise just use a good amount of transmission fluid and be careful. Anyway, drop the input/reverse assy. into the case, get it down on the clutch plate teeth all the way, and then get the band on. You can move the input side to side and pop the band onto the anchor pin and apply pin with a screwdriver. Then drop the pump in with the new gasket, make sure the holes line up well, and then bolt it down evenly. Trending Topics
Thanks for the contact info! Thats awsome... just 15-20 minutes up the road... and I'll be getting my ATSG manual and maybe even the update supplement. BTW, I was looking at your sig banner... I like the SGM Bird... I had one of the FEW '98 SGM Ws6 Drop Tops with the A4... it was one of FOUR drop top SGM WS6's made! Damn I miss that ride! Couldn't handle driving here in the midwest snow... and couldn't afford a second car! Maybe someday I can get it or one of them back!
Brains-
Thank YOU for the wonderful information. Sounds simple enough... and if it weren't for finding the manual locally, I'd be doing the job this weekend WITHOUT the manual... but... since I can get the manual... might as well be safe. Who knows... maybe I can learn a trick or two.
Thanks again guys!
A good friend of mine has the 1 of 1 Inverse 30th... I had a couple pictures with the two of them side by side... but I can't seem to find them... oh well... If I ever trip across that thing in the future I will probably buy it back... If not, I might actively presue it again... like I did for nearly three years before I bought that one! lol Live and learn! I also used to manufacture the clear license plate covers for the Firebird/Trans Am...
TTYL!
