LS1 vs. Truck Coils. Problems?
Old Mar 18, 2004 | 08:58 AM
Zzambucca's Avatar
Default LS1 vs. Truck Coils. Problems?
I bought a set of truck coils and brackets for my ls1 because I was told that there was no difference except the appearance of the coils themselves. My problem is that the drivers side bracket seems to be pushing into the purge solenoid thing on the drivers side of the intake behind the throttle body. They look the same, so I didn't think there was a left and a right. Are the truck and LS1 brackets spaced differently from the valve cover? Its not really a problem, I can do a little creative clearancing. Just wondering.
Old Mar 18, 2004 | 12:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I just bought truck coils, brackets, and the coil harness for my car (98 Formula) can you use f-body harness with the truck coils? I was told no.
Old Mar 18, 2004 | 01:07 PM
matt346ls1's Avatar
They will work ....
Matt
Old Mar 18, 2004 | 01:27 PM
Zzambucca's Avatar
I was told that if you take the the coils and the harness, that it will swap. The truck coils don't hook up to the ls1 coil harness. They both plug into the engine harness though.
Old Mar 18, 2004 | 03:43 PM
LS1Tech Co-Founder
Valvegod said the truck coils will not plug into the f-car harness please advise.
Old Mar 18, 2004 | 04:01 PM
matt346ls1's Avatar
Ask Tom Kempf he put them on his car last week before the shootout, they seemed to work okay.
Matt
Old Mar 18, 2004 | 04:13 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
The actual plugs on the coils themselves are different, but if you have the truck coils WITH the coil pack harness, then that assembly will plug into the F-body engine harness. The white connector in the middle of the valve cover is the same on all applications.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Mar 18, 2004 | 04:17 PM
LS1Tech Co-Founder
Yah I have Melco truck coils, brackets, and the harness.
Old Mar 21, 2004 | 04:39 PM
xjarayax's Avatar
I did the same thing. Had problems where the fuel rail connects to the fuel line (clearance issue by new coil pack)
Evap solenoid will no longer mount to intake manifold (again, just a clearance issue)
Brackets are definately different.
Wiring harness is different, and is not interchangeable.
It will plug into the PCM harness regardless though, but if you are using truck coils, you will need a truck coil harness.
Old Jan 26, 2015 | 05:26 PM
shepss217's Avatar
Yeah i have the same issue with the purge valve, so how can we move this or delete? I was thinking if i ran rubber hose instead of the hard plastic line to the intake itselft then just moved the valve but wasnt sure if this had been attempted or not
By Brett Foote | 2026-06-04 05:00:17
