LSxChevelle Pro-Touring Build
Old Apr 3, 2012 | 02:14 PM
  #41
LSxChevelle's Avatar
Bumpstick ordered this morning...
Thunder Racing seems to be having some business issues so I called Geoff @ EPS and bought a 226/234 .598/.601 113+2
His reputation is great and the EPS lobes seem to be very popular so I'm excited to finally get that purchase out of the way.
Old Apr 4, 2012 | 05:43 AM
  #42
oldgoat69's Avatar
I am going to look into the whole rocker/spring/cam thing after I get the chassis all sorted out. But wait, I still need to install the new top kit I have been moving around the garage all winter. It may be fall before I finally get to the next step. I really want to drive this thing this year. Seems like I start a big project that takes the car off the road every summer.
Old Apr 6, 2012 | 03:31 PM
  #43
What pan did you use? You have the Doug's adapter plates and headers correct?
Old Apr 6, 2012 | 03:39 PM
  #44
chuckd71's Avatar
After looking around a bit I got one from him as well (speced by Pat G). They seem to be the guys to go to for cams going into rectangle-port motors. Can't wait for it to get here.
Did you get the 7.425 push rods? What springs are you going to use?
Old Apr 8, 2012 | 12:36 AM
  #45
Patriot duals that I had laying around and scored a set of used TR 7.425" pushrods for $65 shipped.
Old Apr 9, 2012 | 05:47 AM
  #46
oldgoat69's Avatar
I used a Canton pan, 13-274, pickup 13-275 and filter mount 22-631. It all fits very well, even as low as it could get everything the pan hangs about 1/2" below the crossmember. The tie rods just barely left a witness mark on the pan. Best part is no leaks! Moroso also makes a similar pan, but it requires a remote filter mount. I am not sure if the Canton filter plate would work. You could ask Frank at Moroso if he has an alternative.
Old Apr 9, 2012 | 05:50 AM
  #47
oldgoat69's Avatar
Sorry, missed the last part. Yes I used Dougs headers and plates with Energy Suspension pads 3-1117G. Also used 3378 frame brackets from carpartsdiscount.com . This was the combination that set the engine the lowest in the chassis. It would not be a big deal to shim everything up for better ground clearance.
Old Apr 19, 2012 | 12:29 PM
  #48
Got a few things accomplished today.
Ordered a C5/C6 pressure side P/S line and a generic return with a u-cut hose. The pair were $30 and will be a direct fit on the C5/C6 pump and JGC box.
Also ordered the remote reservoir setup and a pilot bearing.
Old Apr 19, 2012 | 02:47 PM
  #49
85MikeTPI's Avatar
Where'd you order the P/S hoses from?
Old Apr 19, 2012 | 03:09 PM
  #50
Pressure side was Gates 363180
http://www.rockauto.com/catalog/rafr...-363180-303047
Low pressure was found by FatfreeGTO (Thanks!)
http://www.napaonline.com/Catalog/Ca...713_0317318506
Here is his...
Old Apr 19, 2012 | 04:16 PM
  #51
RDRAGE's Avatar
Gd update. !!! placing my order tomorrow for the lines.. Did u ever change over to the cts-v pan ?
from i still havent decided what mounts and headers to get yet.
Btw!!!! i did what u told me to do on spraying the cover's can out gd.
DECISION !!!!! DECISION!!!!!!! what mounts and header's ???? I think alot of people and just waiting for that perfect combo.. info.
Old Apr 19, 2012 | 08:29 PM
  #52
I did I order the CTS-V pan. As soon as pan is here I well drop motor in and show all clearance areas. I'll also list all parts for my combo.
Old Apr 19, 2012 | 10:43 PM
  #53
RDRAGE's Avatar
I got my eye on your build.
Old Apr 22, 2012 | 08:16 PM
  #54
Well drivers header hit due to proportioning valve. So I did some gentle massaging and all good. Also laid out the full exhaust so I...well just because us car guys do that stuff haha.
Old Apr 27, 2012 | 02:13 AM
  #55
******* rain stopped me from installing in the car since the Camaro I'm working on is in the garage. Hoping the clutch can handle the motor...lol Bought off friend with the 429 2011 Camaro...rated for 1595 tq!
Old Apr 27, 2012 | 08:55 AM
  #56
weircc's Avatar
nice build keep up good work!!
Old Apr 27, 2012 | 04:55 PM
  #57
Thanks, once it's running it will be a while before the suspension/body get touched. Getting married in Sept...
Old Apr 29, 2012 | 12:48 PM
  #58
oldgoat69's Avatar
Looks like you are making headway. My project is at a temporary standstill. I decided to replace the convertible top. That opened a new and bigger can of worms. None of the instruction sheets for the project seem to agree with one another. So like most all other projects I shall charge forward with equal parts brute force and ignorance!
Old Apr 29, 2012 | 01:37 PM
  #59
Bullitt4110's Avatar
Very nice build! And thanks for the p/s line part numbers.
Old Apr 29, 2012 | 06:49 PM
  #60
Ah...finally!
