Fox body...AJE users...Steering shaft ?
Doing a 88' GT with a LQ4. I've got a AJE K member and Dynatech swap headers. The car has the stock steering shaft (from column to rag joint)
It hits the back primary tube of the headers and won't work. What are you guys using? This is the only issue I've ran into with the swap.
TIA
TIA
I had to dent the header and loosen the steering wheel support bracket to move the steering wheel over a tad. You have a little adjustment in the motor mounts, too. It's tight but will work.
I've read a lot on here that the older fox body headers were being shipped out SN95 headers instead (94+ cars). I guess dynatech came out with a corrected header for this and was exchanging them out. I don't know the details, you might want to do a search or contact them.
Ok, I bought the headers used off the board. Don't have a nick or ding in them. I just noticed on Dynatech's site it says, to be used with aftermarket steering shaft.
However, I guess I need to call them. Mine have a different part # than either 2 they have listed on their site.
Ok I am not the only one then. I posted a different thread but no one had any input. Does it look like this?
I know the column slides in and out, I pushed it back some I think it can go more and maybe it will clear then. Definitely need the flaming river steering shaft as the rag joint prevents the shaft from even sliding on the rack when the motor is shifted all the way towards drivers side.
Also any info on how to move the steering wheel over for clearance? I am assuming this is what someone meant by the column can be moved left and right some.
Oh yeah. You have the sn95 headers. The drivers side is different than the ones for a fox, as you can see mine go out and around the steering shaft. I have read about people calling dynatech and they took care of the problem for them, but I am not sure if they will do it since you bought them off of someone.
Is this the telescoping one that you got? Are the u joints smaller on this than the stock shaft?
Also did you guys pull your column out or push it in at all for clearances? I know I can get the stock shaft to clear the back primary if its pushed in close to the firewall, but its about 2 inches too short.
Alright sweet. I guess I will be getting this then. Do you know if the top ujoint is smaller than on the stock one as well? Its just like my column comes out right into the primary so I have to push it way back to get the shaft to slide in.
The steering shaft stub that protrudes through the firewall can be moved out away from the headers by loosening the 4 nuts that hold the steering column in under the dash. You can also pull that stub out towards the front of the car thereby lengthening it which will also give you a little more header clearance. I'd spray it down under the dash with some wd40 then put a long screw driver through the bolt hole and pull it. You can usually get them to pull out 1/2 inch or so.
Actually got the joints from a buggy site I think, just like something you would get from Jerry Bickel but for less monies
[IMG][/IMG]
[IMG][/IMG]
Sorry it took a bit. And don't know if it would help but I've got some brand new kooks ss fox/ls headers for sale...
[IMG][/IMG]
[IMG][/IMG]
