g body suspension for LSx
Old 01-30-2012 | 04:26 PM
lemkerailroad's Avatar
Default g body suspension for LSx
i am converting my 81 regal to a LSx powertrain but i am looking to replace my control arms, are they the same as a 2001 2wd blazer?????
Old 01-30-2012 | 04:41 PM
dashboarddevil's Avatar
No. G-bodies shared their front suspension with S10s of the same era.
Old 01-30-2012 | 05:06 PM
this is why i am asking
85 mcss and 2001 blazer 2wd upper control arms are the same p/n from dorman 520-137 & 520-138
but i cant find a lower control arm # for a g body from moog, dorman, mevo or napa?????
ball joints upper and lower are the same upper control arms are the same
sorry if i confused some people in original post
Old 01-30-2012 | 08:02 PM
SPDMETL's Avatar
You have Your own railroad now? Sweet!
Old 01-31-2012 | 09:06 PM
SPDMETL's Avatar
Use aftermarket upper and lower-by the time You buy and install, go for the improved handling.
Old 01-31-2012 | 11:13 PM
spacemanspif's Avatar
You can put the spindle on your control arms if I'm not mistaken. The 2wd blazer Xtreme came with big rotors and dual piston calipers. They need a little bit of tweaking but pretty much bolt in. These spindles have a more expensive bearing to replace but accept an even larger Camaro rotor and caliper. Look on g-body sites for more/better info...this is just a short summary that is probably not very accurate.
I like: www.montecarloss.com & www.maliburacing.com. There are dedicated Regal/Grand National sites as well as the gbodyforum.com
Quick Reply: g body suspension for LSx
