stock lq4 intake replacment
Old Feb 2, 2012 | 11:59 PM
triplepjake's Avatar
Default stock lq4 intake replacment
I am wanting remove the stock truck intake, so it will fit under the hood of a 69 camaro. What is the best intake to go with. Will the LS3 intake fit on the stock 317 heads. I plan on changing the heads down the road to the ls3.
Old Feb 3, 2012 | 08:58 AM
Old Geezer's Avatar
Nope. Wrong port configuration.....
Old Feb 3, 2012 | 09:22 AM
mille_3's Avatar
an LS6 intake will fit your 317 heads.
Old Feb 3, 2012 | 09:23 AM
DarkFox118's Avatar
ls3 intakes are setup for rectangle port heads. Your 317s are cathedral port.
an ls1/ls6 or any of the FAST cathedral port intakes will work.
if you plan to go rectangle port in the future.. I'd get a cheap ls1 takeoff for now and run it as is..
the ls3 intake outflows the ls6 intake, and with the rectangle port ls3 heads.. you'll be doing well.
Old Feb 4, 2012 | 06:46 AM
rp0029's Avatar
Just get the ls3 heads now. You can get them for like $600.
Old Feb 4, 2012 | 06:47 AM
rp0029's Avatar
You also have to change the water pump. The ls intakes won't clear the truck pump.
