Maf problem
Old Feb 9, 2012 | 06:40 PM
WVUSierraC3's Avatar
Default Maf problem
Hey guys,
I have an LQ4/T56 combo in my 69 Camaro, Its throwing a p0102 which is low voltage from the maf. I put my multimeter on the plug and its getting 7 volts rather then 12. Does anyone know what could be causing this? Any help is greatly appreciated.
Thanks
Tom
Old Feb 9, 2012 | 06:47 PM
Intimidator02SS's Avatar
Were you backprobing the connector with it plugged in? Or testing with it unplugged?
I don't have a wiring diagram handy right now, but possibly the reference voltage that feeds your MAF also feed other sensors and one of those could be bad.
If your MAF reference voltage comes is by itself, you need to check at the source.
Also, try piercing the wire 3-4 inches away from the connector and testing again. Could be bad connector.
Old Feb 9, 2012 | 09:01 PM
i r teh noobz's Avatar
I'm assuming you probed the pink wire coming into the MAF with it unplugged? If you only have 7 volts there, you have a corroded connector, broken/cracked wire feeding the plug, or possibly a loose connector for the ENG1 fuse holder. You can try running a temporary jumper from the fuse to bypass the harness and connector to see if the code returns.
I'm not entirely sure what else is powered by that fuse, as all my documentation pertains to my stripped down harness that only has the MAF left on that circuit. If it powers something else, check for shorts and such there as well.
Old Feb 10, 2012 | 07:09 PM
Default maf
Hey guys turns out the ground was bad.
Thanks
Tom
Old Apr 21, 2012 | 02:11 PM
miss_daisy's Avatar
I had the same problem. A wire melted on the exhaust and blew the ENG DEVICES fuse. I fixed the wire and replaced the fuse-good as new. Everyone's advice and input was very helpful.
Old Apr 23, 2012 | 07:52 AM
Symon623's Avatar
Thanks
Tom
I had that code, a few others and driveability issues and it was all ground circuit related...... Will be the first place I look anymore.....
