2011 camaro intake on a lq4
Old Feb 10, 2012 | 05:48 PM
uneek1976's Avatar
Default 2011 camaro intake on a lq4
Noob question but what kind of intake is on a 2011 camaro 6.2 and will that intake fit on a lq4?
Old Feb 10, 2012 | 06:49 PM
Nova 404's Avatar
Not unless you swap the 6.2 heads as well.Whole different port design
Old Feb 10, 2012 | 07:01 PM
rfrankb4's Avatar
Ls3 heads are reasonably priced and flow significantly better so not a bad swap.
Old Feb 10, 2012 | 07:57 PM
uneek1976's Avatar
What do they usually go for?
Old Feb 10, 2012 | 08:00 PM
uneek1976's Avatar
what are 243 heads from those are the heads I thought about using?
Old Feb 10, 2012 | 08:17 PM
v8envy's Avatar
243 Heads are Ls6 5.7L heads, also commonly found on 5.3L truck engines like the L33, there good heads but not with a Ls3 intake, wont work. If you want to use the Ls3 intake, DO it, but get some L92 heads on your 6.0 and you will make a lot more power then with a 6.0 243 combo for not much more money!!!
Old Feb 10, 2012 | 08:42 PM
uneek1976's Avatar
Ok thanks for the info. Would $210 shipped be too much for a ls3 intake with injectors probably the rail but not tb?
Old Feb 10, 2012 | 08:59 PM
rfrankb4's Avatar
900 a set complete. 243s will be the cathedral port heads.
LS3 and L98 heads are the rectangle ports you could use with the LS3 intake which flows mighty well itself.
Those heads are the same except for the intake valve which is hollow sodium filled on the LS3 and solid on the L98. As i understand it some of the corvette LS3 heads also came as a very slightly more smooth casting for the runners but not a major difference.
Old Feb 10, 2012 | 09:47 PM
uneek1976's Avatar
Guys thank you so much cause I'm learning a lot here.
Old Feb 10, 2012 | 09:48 PM
uneek1976's Avatar
Now l92 heads would come off what vehicle?
