PCM swap question
Old Feb 11, 2012 | 12:42 AM
N20neenee's Avatar
Default PCM swap question
I searched and didnt find anything to my satisfaction.
Is there a guide that shoes what model PCM goes with what year? I have a harness for a delphi (sold Im told) and purchased a PCM of ebay thinking I would have it flashed so it didnt matter it was not for an LS1, but the PCM less pins than the harness and wouldnt allow for it to plug in. Im thinking maybe a difference between 6cyl and 8cyl or standard vs auto PCM?
Any help would be great
thanks
Sean
Old Feb 11, 2012 | 08:14 AM
LS1MCSS's Avatar
What do the ECM plugs on the harness look like?
Old Feb 11, 2012 | 09:44 AM
N20neenee's Avatar
Here are the pictures of the connectors. The harness has red and blue connectors. You can barely make out the PCM does not have pins on its outer side of its connectors
Attached Thumbnails PCM swap question-img_1040.jpg   PCM swap question-img_1041.jpg   PCM swap question-img_1044.jpg
Old Feb 11, 2012 | 03:01 PM
N20neenee's Avatar
Based on my Harness, what PCM would I be looking for?
Old Mar 5, 2012 | 01:14 PM
N20neenee's Avatar
Can anyone weigh in this? Based on my pcm connectors, what pcm model/year do I need?
thanks
Sean
Old Mar 5, 2012 | 01:51 PM
psiconversion's Avatar
LS1Tech Sponsor
If this is a drive by cable engine, you can use either an 896 or 411 (both are red and blue pcms) that will work with that harness.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Mar 5, 2012 | 02:32 PM
MNMCSS's Avatar
Do you know what the harness is from??
Old Mar 6, 2012 | 02:52 AM
N20neenee's Avatar
The harness is supposed to be from a Corvette that was turned into a stand alone harness, but the fuse box is huge. I will post a pic. I bet its a truck harness that the guy striped out. I got ripped off on ebay is the bottom line, so now i gotta make it work. Thanks for the inputs
