Novak vss hook to 5.3 harnass
Probably a stupid question but ...
I am at the point of attaching the VSS included with the Novak adapter to my 5.3 Vorted harnass. The sendor has two black black wire, I assume its just a std Prox sensor an there is no issue of polarity but I want to make sure before attaching.
The harnass has a plug which traces back to
pin 20 LT GRN/BLK 822 VSS Low Signal
pin 21 PPL/WHT 821 VSS High Signal
Do I just attach the two wires from the Novak sensor to the two wires in the harnass or does one go to ground and the other to one of the above 2 wires.
Many Thanks
Many Thanks
thanks, I assume you meen it attaches to the two terminals mentioned in my first post
