Stock chevelle radiator
Old Feb 12, 2012 | 08:14 PM
firehawkta81's Avatar
Default Stock chevelle radiator
I am continuing my LS swap on my 66 El Camino. I am wondering if I can use my radiator? Radiator is about two years old and would like to be able to keep it.
Old Feb 12, 2012 | 10:35 PM
bczee's Avatar
Yes, No reason that you cannot. One are of concern is the Upper Radiator hose size of radiator. It is usually larger that the Gen III/IV water pump inlet size. Not a hard thing to fix.. just need to find a hose that has both of the correct size or a reducer.
But your question should be, does the Radaitor have the capacity to meet the engines cooling requirement.. If your engine is stock or mid build. It should be ok. If Supercharged or Turbo or a lot of Compression.. might be another story..
BC
Old Feb 13, 2012 | 12:57 AM
Thanks for the info, it's a 6.0 with a mild cam. Capacity I believed was okay, it cooled my 383 Stroker perfectly. I wasn't sure if the flow of the radiator is the same. Thanks
Old Feb 13, 2012 | 11:00 AM
Also, will a stock radiator accept the red coolant that the LS uses?
Old Feb 13, 2012 | 02:31 PM
bczee's Avatar
You would have to flush the Radiator complete as the Dexcool is not compatiable with the Green stuff.. If you mix the two. you well get a bad mess !
I elected to flush the engine out well.. then use Green/Blue stuff.
BC
Old Feb 13, 2012 | 09:33 PM
LS1 pwrd NOVA's Avatar
What headers and mounts are you going to run?
Old Feb 14, 2012 | 12:51 AM
I am using Speed-tech ATS motor mount plates, have not chosen headers yet.
