02 Firebird 5.3L - Need Oilpan Advice...
I was looking at this...
http://www.superchevyperformance.com...p/19212593.htm
Can I use this?
If not, if I do get the F-Body oilpan and pickup, can I use the 5.3L Windage tray?
Can I use this?
Get a LS1 F-body one, and cut down the Windage Tray.
The H3 one will hand below the cradle.
Nice link too, you would think that there would be enough QA to spell check.
From: Central Indiana Honors: 4th grade spelling bee contestant
If you get the f-body oil pan, you might be one of the lucky ones to get a freak one
The standard f-body oil filter wouldn't thread onto mine, but I got the Hummer oil filter to spin on tight.
I was curious cuzz if I could get 400 HP N/A while being streetable with a 4.8 I might go that route instead.
Can I use this?
Can I use this?
Also, I may be willing to part with...Going to look more into the comparison between the CTS-V pan and the F-Body for my Chevelle. Either way I plan to trim the rear of crossmember for good clearance.
Jason
lol the irony, you're the guy helping me do my swap - but thanks... I ordered the windage tray as well as my oil pan & pickup.
