GNIUS's LS6 G35 Build
Great looking build by the way glad to see more of these popping up.
C5R Timing Chain and Crank Turning Tool (This is a godsend!!)
Custom ground EPS 226/230 .600" lift cam.
The new cam, all lubed up and only one place to go...
It went in so good!!
Rear Seal and Rear Cover are in!!
I was interrupted by the mail man. He had a present for me!! Timing chain damper came in!!
Cam retainer plate is in and I drilled and tapped the block for the new timing chain damper!!
Cam timing mocked up. Dot to dot. Pretty simple.
Timing gear, C5R chain, and timing chain damper installed!!
All done for today. Short block is almost done!! Just need an oil pump and front cover.
Thanks!! I totally agree. Have always wanted to build a motor. Maybe more now since I have all the tools
I am waiting on a few parts and tools right now. I did some prep work for paint on the intake manifold. So its coming along. Should have a decent update with pics soon.
I also need some opinions on colors for the heads and valve covers. I am torn between colors cast iron and aluminized. I did a color swatch for the cast iron and will do the aluminized tonight and post it tomorrow for input.
Melling oil pump came in:
Oil pump installed:
LS2 Front cover and cam sensor came in:
LS7 and new LS2 lifter treys with hole mod lubed and prepped for install:
LS2 Timing cover, LS7 lifters and guides installed!
PSI Springs just came in:
Yeah, I have since sold my old G35 parts and have decided porting is a bitch and I dont want to screw it up cuz I dont have a flow bench. I have decided to go with sending my 243 heads to Advanced Induction.
LS2 intake and LS2 heads are interchangeable and they are still cathedral ports LS3-LS7 are the rectangle ports.
Also, I found a sweet deal on a busted T56!! The syncros between 2-3 are gone. I am now procuring parts for a viper T56 spec build.
In all seriousness, I'm glad to see thats its being put to good use and that the project is going well. I will be following this build.
