home made selectra wiper
Old Mar 20, 2004 | 09:27 PM
gEtyOPaPiOn's Avatar
Default home made selectra wiper
not as nice but way cheaper...just some more trimming is required and then hand polish ...300 ? ....30 ? ummm ill stick with 30 lol
Attached Thumbnails home made selectra wiper-homemade1.jpg   home made selectra wiper-homemade12.jpg
Old Mar 21, 2004 | 09:25 AM
LS1swap's Avatar
Forgive me for going totally off topic but is that lookar dipstick for the engine or trans? I wanted to use one for my engine but didn't know if it would fit.
Old Mar 21, 2004 | 01:08 PM
JORD's Avatar
Hey bud, I was wondering if we could get a lil more info on your wiper setup. At 30 bucks, that's a steal! What's the motor off of? Was the wiring much different? Details man, we need details! heheh
jared
Old Mar 21, 2004 | 02:07 PM
OK HERE ARE THE DETAILS LOL.....93-02 CAMARO WIPER MOTOR(10 DOLLARS EBAY) ALUMINUM PLATE ANY THICKNESS YOU LIKE (EBAY 10 DOLLARS) 3 HOLES FOR FIREWALL 3 HOLES FOR WIPER MOTOR ...DONE! WOW THAT WAS SOME QUICK 300 DOLLARS LOL
I WENT WITH A THIN PLATE BECAUSE OF MY MOTOR BEING SO CLOSE TO THE FIREWALL ...AND I POSITIONED THE WIPER MOTOR DIAGONAL BECAUSE I DIDNT WANT TO BLOCK THE TRIM TAG ..I BELIEVE THE SELECTRA MOTOR DOES...NOT SURE ....AND AS FOR THE WIRING IM IN THE PROCESS OF FIGURING THAT OUT LOL IT SHOULDNT BE THAT HARD.. I FIGURED OUT THE SLOW AND FAST SPEED I JUST NEED TO FIGURE OUT THE INTERMITENT SPEED ...OH DID I TELL YOU IT ONLY TAKES MINUTES .....YOU THINK !!!
Old Mar 21, 2004 | 05:51 PM
HotRod68Camaro's Avatar
keep us updated man. let us know when uv got all the wiring done and how to do it b/c i need to do the same w/ my 68. thanks
Old Mar 22, 2004 | 07:17 AM
67ls1CamaroProject's Avatar
How does it attach to the linkage?? Using the first gen linkage?
Old Mar 22, 2004 | 06:21 PM
Oh Yeah ...blend In The Old One With The New One ...drill 2 Holes Easy Too Or You Can Weld It If You Want ...i Welded It But It Can Be Drilled There Is Plenty Of Space
Old Mar 23, 2004 | 02:49 AM
pjtimmer's Avatar
Will this work for a second gen too?
How is the linkage and the movement lenght.
I have the wipermotor that is similar to the '69 camaro.
how about the window washer pump?
nice work
thanks
Peter
Old Apr 12, 2004 | 12:18 PM
Drill or weld what? Blend in old "what" with new "what"?
I just bought a 2000 wiper motor. I see that it has a splined female shaft to adapt to the wiper crank. Did you use the 2000 crank or did you use the 67 wiper arm crank. If the latter, how did you attach it to the new motor? If the former, does it connect to the 67 linkage? The length of the crank looks to be longer than the 67...so this would make it over travel. Please give me some more clues. I haven't taken my 67 motor out yet, so maybe I am missing something that would be evident.
