oil pan pics
Comparing to a notched F-Body pan.
With engine mounted. with moving the engine as low and forward as I could, contact
Moved the engine back a bit and rasised it some.
That about it...
BC
There is a reason BRP when with Design #2..
The Gen III/VI engine are about 1" short than a SBC engine. GM want to make the engine fit into smaller engine compartments.. How they did this. .was to shorting the block at the rear of the engine.. if you look at a SBC.. the flange where it bolts to the bell housing is about 1" to 1 1/2" wide.. the Gen III/VI is shorten by 1".. that is one of the reason why many say you have to move the engine back 1" (with 1" setback plates) to mate the engine up with the Trans/bell housing (if the trans was left in the stock location).
If you use standard plate (S&P or ATS) and the frames stand are now where the SBC frames would line up. No.. you would be just doing a S&P swap plates and would require a notch F-Body pan to clear the crossmember.
I have said the best thing to do is just mount the plates, engine mounts and Stand together and to the engine, then just drop it in, move the engine to where you want it to be and then mark the location where the stands end up, removed the engine and either bolt or weld the frame stands in place.
BC
The Holley pan looks like it will clear. The ground clearance is higher than the crossmember.
Tim
That and the MAST pan should fit just about everything due to the smaller rear sump. I wish they had a better inner baffle.
The GM muscle car (H3) pan is deeper than the CTS-V and other truck pans even deeper than that.
I'm guessing you probably want to avoid that though...I think it comes down to mounts as well. So many variables with mounts, pan, headers, accessories, blah blah...
