LsxFox need help wiring this beast to run
Old Feb 22, 2012 | 12:04 AM
bakomack's Avatar
Default LsxFox need help wiring this beast to run
05 5.3 DBW w/ 4l60e
camaro cluster
using a truck harness thats been modified for this swap
I have the cluster plug and an obd2 plug that also need to be wired in
on the harness theres 5 power wires:
1 yellow; 12v constant
1 purple: starter
3 red: 12v ignition power when key is on
harness also has 10 data wires:
AC clutch activation
OBD2 data port
brake switch (need for torque converter lockup)
vss to gauge
malfunction lamp
4 cylinder signal to tach
ac clutch relay control
stop lamp switch (12v when brake is pressed)
fuel pump relay control ( puts out + to turn on relay)
obd plug:
(2) purple: serial data line
(4) BLK: ground
(5) BLK/WHT: ground
(16) orange: +12 v batt (not ignition)
cluster plug:
B1- park lamp feed
B3- security indicator input
B5- fused ignition feed
B6- tach
B7- rear compartment lid ajar
B8- vss
B9- instrument cluster lamp feed
B10- right turn indicator input
B11- ground
B14- oil pressure gauge input
B15- ground
A3- fused ignition feed
A5- brake warning indicator lamp input
A8- service engine soon indicator lamp input
A10- fused batt feed
A12- left turn indicator
A13- fasten seat belt
A15- low coolant indicator input
A17- high beam indicator input
I do have an after market oil pressure, water temp, and fuel level gauge
but id like to have as much functioning as possible on this cluster.
im not the smartest when it comes to wiring but im ready to finish this car and the wiring is about all I have left.
I would greatly appreciate the help and when the car is finished and bugs worked out plan on doing a DIY lsxfox thread.
thanks guys
Old Feb 22, 2012 | 07:10 AM
bjamick's Avatar
Here this will help you on what wires need to be hooked up to the camaro cluster:
http://www.auto-wiring-diagram.com/w...generation.jpg
Are you needing to know how to wire up the obd2 port?
