adjustable alternator bracket
Old Feb 22, 2012 | 11:38 PM
2baditsnotachev's Avatar
Default adjustable alternator bracket
Im swapping a 5.3 into my 70 nova and I want to run the alternator drivers side low. Does anyone make an adjustable bracket for this area? I've see one but it was only for the 6.0 block. Im ditching the water pump for a remote setup so ill only be running the alternator, will I even be able to find a serpentine belt that short?
Old Feb 23, 2012 | 06:53 AM
Pop N Wood's Avatar
The belt number tells you the length. Gatorback 4060290 is the shortest 6 rib belt summit carries. The "60" says it is a 6 rib belt while the "290" says it is 29.0 inches. The lengths go up from there sometimes in half inch increments.
If 29 inches is still too long then look into some way to run a tensioner. I prefer having a spring loaded tensioner anyway.
Old Feb 23, 2012 | 10:32 AM
Thanks I did think about solid mounting the alternator and making a bracket to hold the stock tensioner also. Will the bolts in the timing cover be strong eniught to hold the tensioner?
Old Feb 23, 2012 | 10:35 AM
Gray86hatch's Avatar
Bmr makes one.
Have a remote pump on mine.
Uses f-body balancer
Tim
Old Feb 23, 2012 | 10:37 AM
tim99ws6's Avatar
AEIcnc.com makes one.
Old Feb 23, 2012 | 10:56 AM
Old Feb 23, 2012 | 11:39 AM
streetknight2's Avatar
Where can I find info on the remote water pump setup, never heard of it. I'm doing 6.0 in foxbody and need to take care of this same issue. Just need to run alternator and water pump
Old Feb 23, 2012 | 11:50 AM
Meziere pump. Welded to the rad with -12 lines. Moroso adapters to the block. I have a t-stat in mine
Works really good on the street.
Tim
Old Feb 23, 2012 | 12:01 PM
Do you have any pics of the way its done at the pump and radiator? Could you tell me which meziere?
Old Feb 23, 2012 | 12:37 PM
Old Feb 23, 2012 | 12:40 PM
Old Feb 23, 2012 | 12:43 PM
Old Feb 23, 2012 | 01:40 PM
Is this remote setup more or less expensive than the Meziere that bolts on the block?
Old Feb 23, 2012 | 01:50 PM
cyipher's Avatar
How did you mount the thermostat? who makes a piece to inline mount it with 2 -12 fittings?
Old Feb 23, 2012 | 02:00 PM
http://m.summitracing.com/parts/MEZ-WP362
Moroso makes the -12 housing.
Old Feb 23, 2012 | 03:09 PM
cyipher's Avatar
no im talking about the piece on the top radiator hose off the 90
Old Feb 23, 2012 | 03:20 PM
$15 BBC thermostat housing
Old Feb 23, 2012 | 03:28 PM
cyipher's Avatar
part number? i can find any that have 2 -12 fitting into them...
Old Feb 23, 2012 | 03:33 PM
http://www.summitracing.com/parts/MOR-63425/
this is the black piece
http://www.summitracing.com/parts/BSP-90120/
Like this welded to the radiator
Old Feb 23, 2012 | 03:45 PM
Prorac1's Avatar
What is the advantage of doing this over a regular meziere electric LS water pump? Eric L
