93 POS notchback build
everything fits pretty nice so far!!!
Location: All fuel tanks, lines, pumps, valves, etc. must be outside
of the driver’s compartment and within the confines of the frame
and/or steel body. Cool cans, fuel-distribution blocks, etc. must be
located at least 6 inches forward of the flywheel/bellhousing area on
rear-wheel-drive (RWD) vehicles, and on opposite side of
flywheel/housing area on front-wheel-drive (FWD) vehicles. Fuel
pressure gauge isolators, with steel braided line, may be mounted
on firewall.
on firewall.
i fabbed up my dipstick tube. i took the stock ctsv one and cut the flange on it and rewelded it and bent the tube to fit. it looks stock and fits perfect.
this motor is pretty much ready to run at this point. im starting to get excited every time i work on it cause it feels like alot of progress is being made. im going to clean up the engine bay while the motors out. its pretty ******* disgusting lol.
also wanted to see if the dipstick cleared. clears just fine.
relocated the FPR (**** you kyle).
and finally a pic of the BOV and LS7 maf.
had to send my crossover pipe back to the welder to get a gusset to support the wastegate and when thats done i wont have to pull the system apart againuntil i put the cam in it. in a nutshell the engine compartment is almost done. next phase will be the chassis and i cant wait for that.
