engine temps
Scott
Try a lower thermostat temp. I have a 160° unit and temps generally stay within 15° of that. That is with a single pass, single core radiator out of an Astro van.
What gauge setup are you running that show the temp to be 15 degree higher ?
BC
I'd check for air in the system if it hits 220. I have to bleed mine from the steam pipes where they bolt to the heads every time I fill it up.
I have tried removing the thermostat and clamping a 1/2" hole washer in to the hose for restriction and no change. I can't raise the radiator up so I am thinking of putting in a swirl pot to have an effective high point in the system. I have also read that possibly running lines from both the front and rear steam vents to a higher point may be more effective. At a track day this weekend I hit 228 and pulled it off the track. I know its pushing the engine hard but there is plenty of air flow between 60 and 130 mph. When I pulled into pit and shut the engine off it got even hotter and pushed coolant out the overflow.
It seems really weird to have the thermostat on the return side of the radiator and may be part of why these run hot. But on the other hand i removed the thermostat and added the restriction with no change.
any thoughts?
