Lsx swap ideas!?!?
Old Mar 4, 2012 | 04:34 PM
LSx '73 Nova's Avatar
Default Lsx swap ideas!?!?
Alright so I'm wanting to do an Lsx swap with either a 5.3 or 6.0... I just dont know what car to swap it into... I'm looking for something light not like really heavy maybe around 3000-3500 i originally planned on getting a 1st gen 2dr 2wd s10 blazer butr I havent completly decided yet and I want to know what other Rwd cars I could do this to...Perferably late 80s to late 90s cars (chevy perferably)
Old Mar 4, 2012 | 10:36 PM
gMAG's Avatar
A third gen Camaro or Firebird comes to mind.
Old Mar 4, 2012 | 11:10 PM
the_merv's Avatar
Veteran: Air Force
G-body.
S10 is fun tho...
Old Mar 4, 2012 | 11:26 PM
atomic 6's Avatar
find a bricklin SV-1, 75 or 76.
http://files.conceptcarz.com/img/Bri...1_CC_KM_03.jpg
I haven't seen that yet.
J/K You really can't beat the fox body for the weight or traction, or my fav. the regal,monte,cutlass swaps.
Old Mar 4, 2012 | 11:36 PM
bczee's Avatar
A G body would be a affordable option. .maybe a Fox body Ford.. My 71 Chevelle weighted in around 3600 lbs. and My 71 Nova should be around 3000 lbs.
Question, do you have to worry about SMOG ?
Old Mar 5, 2012 | 06:05 PM
Nope no smog here in Arizona
Old Mar 5, 2012 | 06:06 PM
Alright ahah I looked at the link and got all confuzed...Probably shoulda read the whol post first.. thanks man
Old Mar 5, 2012 | 06:10 PM
Originally Posted by the_merv
G-body.
S10 is fun tho...
yeah what's your prefrence since you have both cars???
Old Mar 5, 2012 | 06:15 PM
MNMCSS's Avatar
I think a 6.0 in a s-10 would be pretty wild...
Old Mar 5, 2012 | 06:25 PM
Agreed my dad bought a 6.0 with complete wiring and accesories for 1200 with the 4L80E included not sure if it was the best deal but I think it's gonna be awesome I have fully decided to do a 1st gen 2dr 2wd blazer with a 6.0 with probably around 500rwhp for my goal...L92 heads the whole shabang
Old Mar 5, 2012 | 06:42 PM
john59's Avatar
S 10 Blazer its Light and not very expensive to build just finishing my mock up now
LQ9 6.0/ 799 Heads/ 04 ZO6 cam/LS6 Intake
4L80
8.8 stock width, axles drilled for chevy pattern with C6 wheels and tires
If you need any info let me know
the_merv's Avatar
Veteran: Air Force
The S10 is fun as **** to jet around in cause it doesnt weigh anything..the car is better for the big motor cause it has the *** to hold it.
Old Mar 5, 2012 | 06:52 PM
4L80
do you know if the C6 Z06 or zr1 wheels would just bolt up to your setup? and will I need any modification to the frontto fit the wheels?
Do you know what the Hp numbers will be?
Old Mar 5, 2012 | 06:53 PM
Thanks!
Old Mar 5, 2012 | 06:57 PM
john59's Avatar
And just to let you know talked to Phil today at BRP they make a 1 3/4 in the rail for S10's 45900,the passenger side header hits the rail on 6 and 8 on the Blazer, "BUT" Phil did a mock up that he has sent to Hedman so in about a month or so you can get long tubes which has been a bitch to find that work well
Old Mar 5, 2012 | 07:03 PM
Thanks that's gonna be a huge releif!
Old Mar 5, 2012 | 07:05 PM
john59's Avatar
The 19x10 is about all you can stuff in the stock wheelwell with a 285 tire I'm about 1/2 from the leaf and flush with the lip with a 79mm offset. NO Spacers in rear and 2" in front could of prob went 1 3/4 though I have about 5/8 -3/4 to the tie rod with drop spindles and 2" springs. Hp hmmm I would think about 380 to the tire maybe a bit more. I'll eventually go L92 with a cam and a stall but for now just wanted to finish her off and have some fun
Old Mar 5, 2012 | 07:09 PM
Alright thanks fo the info it will definaltey be used!
Old Mar 5, 2012 | 07:13 PM
john59's Avatar
You'll also have to set the rear back about 1/2" if you use the 8.8 which is easy and actually centers the wheel in the well if not the rear will hit the floor with 3" drop leafs.Using Belltech street and performance shocks, also will be installing a 2WD second Gen Blazer front and rear stabilizer bars
Old Mar 5, 2012 | 07:27 PM
john59's Avatar
Wife said be nice to have an SUV, found a Blazer went to work and here it is,lol.
